Spunbearing
Thread starter- Joined
- Jul 18, 2010
- 4
A friend bought a boat with a late 80's 110hp johnson on it, probably in satwater most of its life from the looks of the corrosion, had the carbs rebuilt at a shop, took it out on the water today and it ran pretty well for about an hour or so, it did have some intermittent issues of losing power at rpm, was on a plane for a while engine at 5700rpm and it seemed to lose power a little bit a couple of times like it had earlier then in just died, got it to start but it would only idle and die if you gave it more throttle, had to idle all the back in a couple of miles, pulled it out of the water and it would rev but had some pretty bad misses. I think its probably ignition, any help would be appreciated. I'm pretty familiar with motors but rather new to marine stuff.
