FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
i have a late 70's 850 merc that won't shut down when i turn the key off. i have to choke it to kill it. has anyone experienced this? if so what could the problem be?
My brother had this issue..In his case it was a bad ignition switch. If it started out of no ware thats where i would start its a easy cheap fix....if it started after engine work was done check your wires and see if the are in the proper place.In that case you would need the wire diagram to trace them....could be a cross keeping power to the coil.
