late 70 110 9.8
robie
hello like to know if any one knows if this motor has a thermastat for the pee hole because i thought i read some where that a newer motor had one because water stops from pee hole and then starts again thanks
Laddies
Banned
Re: late 70 110 9.8
If your engine is equip with a thermostat it might be either a vented or unvented thermostat just pop the top off the housing and look. We have had to open several of the slots or holes they can be either way to get a steady telltell flow for customers.
robie
Re: late 70 110 9.8
how does it look like or where about is it located on the engine if pictures are possible would be great thanks.
robie
Re: late 70 110 9.8
thanks for the picture but still not sure where it goes on the engine do you mean the slot is on some where on the block thanks again
dennyb123
Re: late 70 110 9.8
My motor doesn't have a thermostat. It's a 1979. I'm really not sure if it did originally, but the thermostat housing is is near the left rear of the power head. Near the top. It is held closed by a large spring. Pop the spring off and lift off the top of the housing to reveal if there is a thermostat or not.
Now, all this got me thinking. How do I know if there should be a thermostat installed in my motor?
robie
Re: late 70 110 9.8
perfect thank you so much.
