late 60s early 70s evinrude sportwin 9.5
Big Ol Johnson
9.5 sportwin
it will run good, but not to full throttle, it is like something is restricting it.
F_R
Honorary Supreme Mariner
You mean the throttle twist-grip? Clickin suggests to me the rack and pinion gears are not "timed" correctly.
It has to be in forward gear to go beyond the "Start" setting.
The round idle speed knob on the side of the tiller mount often gets screwed in to far, limiting how far toward "Slow" it will turn.
F_R
Is this related to your other question? Or does it actually lack power? Most common cause of lack of power is running on one cylinder. But, the 9.5 is notorious for inhaling smoke. Does it run ok with the hood off?
Big Ol Johnson
it runs good and doesnt lack power, it just wont let you turn the tiller handle very much at all, also it is related to other question.
Big Ol Johnson
it is not a click when running, it is when you twist the throttle, it has small click intervals, i dont think it has to do with the gears either, i tried that.
Post pictures or a model # of this motor.------The 64 models had a detent on the magplate that would click when it turned !!
F_R
Ah yes! I forgot about that. 1965 also.
That motor has a quite complex shift/throttle interlock system. Hard to describe in words. But I think that is where your trouble lies. You need to examine it in person and see what is obstructing the throttle and deal with it.
