late 60s early 70s evinrude electric shift
kenneth85
where does the two wires connect for the electric shift that come out from the lower unit out past the motor. also someone told me that muffs wont work that it needs to be in a barrel but will i see water come out anywhere
kenneth85
evinrude 40hp electric shift
just bought this boat the 2 wires for the shift are not connected. where do they connect to? they are connected to the lower unit but not the other side. please help:facepalm:
kenneth85
please help
please help
can some please tell me where to connect the wires for the electrc shift wires they are connected in the lower unit but not the other end.... please help anyone:facepalm: 40hp evinrude model late 60s early 70s model number unknown
yorab
Ensign
Re: please help
Re: please help
Those wires run to the control box that mounts at the helm.
kenneth85
Re: please help
Re: please help
do you know witch wires they connect to and i put the motor in a barrel if i had to much 2cycle would that couse oil to be in the water? also is there a spot water should come back out someone else said no
Bob_VT
Re: please help
Re: please help
The wires hook to the harness plug which connects to the cable to the control box.
