chattanoog_josh
- Jun 24, 2011
- 6
never had a boat, had a jetski last year but this is different to me
so out of water it idles and will go into drive and sputter a little but rev all the way out and spin perfectly
in water itll idle ok, sometimes the N is a little wierd getting into, itll be in N and let you start but the propeller will be engaged
but one in N itll idle fine, then try Drive or Reverse it will bog and eventaully die, it sounds like maybe 100rpm above idle then bog then die
