barthel
Thread starter- Joined
- Mar 20, 2012
- 94
I posted this previously but I got wrapped around the axle with some of the responses I got, so I thought I'd make the questions more direct and simpler. Here are my stats as of now;
1) Performance issue you are trying to correct.
Boat is slow climbing out of the hole (4 to 5 seconds) and seems to lose plane easily (below 2200rpm's)
I know I run heavy (4 adults, a kid or 2, 50qt cooler)
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
Volvo Penta QL Aluminum 3 blade
3) Current prop diameter and pitch (required).
14.25X21
4) Wide open throttle RPM and speed with an average load (very helpful)
4000-4200 with an "average" load
Factory tach is off, I'm getting close to factory top speed (I get 47 mph on GPS, factory was 52mph) with a downed prop (factory was a 23p, it has a 21p)
5) Engine/drive make, model, year, and HP
VP 4.3GLPEFS, VP SX Outdrive, 2000 model year/190HP, 1.66:1 gear ratio
6) Boat make model, year, length and weight
Four Winns Horizon 180LE, 2001, 18ft, 2500#
I have pretty much decided to run a stainless steel prop. Would a 14.25 X 21p 3 blade SS prop be my best option or do I have to reconsider pitch when going from Aluminum to SS?
My second choice would be a SS 4 blade, 14.25 X 19p.
I have no handling issues, the boat performs excellent, I would just like to get it on plane a bit faster and hold plane at a bit slower of a speed.
Thoughts, opinions?
BTW, thanks to everyone who answered my previous thread, it gave me a lot to think about.
14.25X21
Thoughts, opinions?
