Laser sailboat restoration - seeking help - brand-new to hobby
JBDO
Good evening everyone. For some time I've been interested in getting into sailing however I am on a limited budget. I recently moved to Traverse City and came across an add from an elderly woman on the peninsula who was trying to get rid of her mid 1980s laser sailboat. I purchased the boat for $5 total. It came with an intact hull and deck with solid hardware (no boom, sail, rutter nor centerboard). There is however circumferential separation between the deck in the hull. The two are joined however by a strong seal around the centerboard hole (terminology?). I had the boat cleaned up nicely but I am trying to figure out the best way to create that joint. My other concern is some of the edge of the deck where it starts to wrap around the whole has chipped off about 1-2 cm in a couple areas. I have done some research and found that white elastomeric polyurethane sealant may be my best option.
If this is a good option, what is the best way to go about joining the two. I was simply planning on putting the boat upside down and generously filling the cracks likely with the use of several vices.
Any help or insight would be greatly appreciated thank you!
tpenfield
:welcome:
After a few posts, you can post some pictures of the Laser using the 'paper clip' icon. Reduce the size of the pictures to 800 x 600 before uploading though . . .
I would make sure the hull has no water in it before you 'glue' the halves back together. You could use 4200 or even 5200 adhesive sealant.
Although the boat was only $5, I think the elderly woman got the better end of the deal, as buying the missing pieces for the boat will not be trivial $$$. Maybe you can do OK on eBay, but you will rival or exceed the cost of buying a complete used Laser when all is said and done.
You said it was missing the boom, sail, rudder, and dagger board. Right? So is there a mast?
the boom will be about $150 used
the dagger board will be $250-300 used
the rudder will be about $300 used
the sail will be about $100
So, along with some running rigging and supplies, you will be into it for about $1,000.
Lasers in great shape would sell for about $3-4K. Lasers in fair condition, but complete would be around $1k. Might even get a trailer to go along with it.
So, if you have not done so, do some research into the cost of making this a complete boat and then decide if you want it as a project, or you want to sail.
JBDO
Thanks for your thoughts. Any idea on my question though? Thanks!
Woodonglass
It's very hard to give advice if we can't SEE the areas in question. As stated post a few more times then upload some pics.
