Larson 226 lXI 1999 - Raising ski rope pole
Andysaul
Can anyone tell me if there is a good ski pole that can be added to this boat without covering to much area? The ski rope ring installed allows the rope to hand in the water. Raising up less than 1" would help. Really don't want to go with large tower or the three leg ones I've seen. Thanks Andy
orion25
Re: Larson 226 lXI 1999 - Raising ski rope pole
Why do you need to raise it? If it is to keep the rope out of the prop you could put some type of flotation near the end of the rope. Maybe some foam pipe insulation held on by zip ties.
