larry pressley
larrypressley
i have a 1987 evinrude 150stlcur on an 18' stratos of the same year. the prolem that i am having is the power trim is not operating properly. the trim works fine when the boat is sitting still or even putting along. the problem occurs when i throttle up and get on top of the water. the boat will get on top but the trim stops trimming making for a very bumpy ride to say the least! can anybody help me with this problem. i am reaching the end of my rope! thanks!
:confused:
oldman570
Re: larry pressley
You need to check the trim fluid and see if the motor is hitting on the trim pin on the transom bracket and not letting the motor trim down farther. Check the pin and move it down one hole closer to the boat and see if it helps.
Oldman570
larrypressley
Re: larry pressley
thank you for your quick response sir. i have checked the fluid already and when i pulled the screw out fluid spilled out so i have to think that it has enough in it, but i'm open to any ideas.
larrypressley
Re: larry pressley
as far as the pin is concerned, the problem is not when i am using the down button but when i am trying to raise the foot of the boat as i am already on top of the water and trying to level out.
oldman570
Re: larry pressley
In order to check the trim fluid the motor has to be in the fluu trim up position to do so. If fluid came out when you check it then you lost some and now it will not work as it should. Getting a manual for your motor will be helpful when you work on the motor.
Oldman570
