Lark Starting Problem
catfishmatt
I have a 72 evenrude lark 50hp it slowly cranks over in gear only won't crank or nothing till I hit the neutral push button then it starts cranking slow in gear how do I get it to go into neutral
Honorary Supreme Mariner
That has been done for you.------Your motor does not shift untill the motor is turning via the starter or when it is running.---It needs oil pressure to shift.---Therefor it must be turning the pump in the lower unit.---Have you checked the oil in the lower unit ? ---Have you installed a known good battery. ----Checked that battery cables are good?---Remove and inspect the starter itself too.---Your motor will not start if it is turning over too slow either.
catfishmatt
It cranks over real slow even with jumper cables is the oil hard to find store wise
You need to check the starter motor.-------Type -C gear oil ( premium blend ) is not hard to find.--See your local Evinrude / BRP dealer.---You might want to remove the lower unit as a test.---Perhaps the gearcase is binding and the cause of the slow cranking.
catfishmatt
It cranks over super slow when I push the neutral button checked the oil in lower it's good
????-------Posr # 7 mentions to test your starter motor.-------------Some motors will only crank over in neutral.-------Perhaps you need to remove the lower unit as it may be binding.------------------Since your motor is not near my workbench , you have to do the inspection and testing.
catfishmatt
Ok will do hope it's a easy fix but from what I hear the hydro shift are complicated
You can not believe everything you hear,----As far as I am concerned the hydro-electric shift is elegantly simple to work on !!
catfishmatt
I hooked my starter to jumper cables and it spins but the gear only stays up for a second is that normal
