lanyard switch
Monte1961
Re: lanyard switch
When you buy it, should have all necessary instructions on how to install it!
Rick.
Re: lanyard switch
Assuming your motor has a factory shorting switch.........remove the shorting switch and the universal (Sea Dog is the brand I've used) kill switch will fit right into the same hole. Wire the existing leads to the normally open (with lanyard installed) contacts. Best of luck. Rick.
