Re: Lake is low, cables don't reach water. Solution?
Hi all, sorry for the late return... Lake level is so low it's had me a bit depressed, but I have not given up on this project.
At first I was going to use about 10' of chain at each corner. I was going to use the chain to hang the boat, then move the end of the cable to the chain via a grab hook. This seemed to give me a lot of flexibility, but it was rather expensive.
So I decided to do the same thing, only with 1/4" wire rope. I went and bought all the stuff I would need, cable, clamps, thimbles, shackles, etc. Added up to over $100. The 100' of 1/4" cable was a reasonable $37.
As I sat on the dock with my two helpers (neighbors and boat owners for many years), explaining the process, it was noted that I have to reverse the process when the water comes up. And if it comes up quick, I'll have to hustle down to Granbury or risk my boat being too low.
That's when we started measuring, and lowered the boat all the way down and measured water under the boat... And determined I'd only need to lower 6' max (before the rear of the logs would touch the bottom of the lake if the water were to lower even more - right now there's 5' of water under the back of the boat and about 4' at the front). Thus adding 12' to each corner (single pulley on strap so 6' x 2) would be just 50' of cable (total). With an existing cable length of about 120 feet total, buying a new longer 3/16" cable (~170 feet) would still be less than all the new bits of hardware I would need with the extra length of 1/4" (since during the process it would support all the weight on the end of the 3/16" cable is reattached) wire rope on the corners. It looks like an extra 12 to 16 wraps of cable along the shaft won't be a problem either. There's about 30 now and the angle looks OK. I know this is perhaps not 100% ideal, but it means the boat can always go all the way up and all the way down, without messing with an intermediate "hanger."
So captain zac, you called it.
To get the old cable off and the new on I plan to lower the boat, clamp the two cables (above the pulley) together and temporarily hang the boat from a single strand (then end attached to the dock via clamps) and cut the cable that wraps around the shaft. With a load limit of 840 pounds on the 3/16" it's enough for the transition until the new cable is installed, which I plan to slip through the pulley, on top of existing cable... Once everything is tight and snugged up, I will cut the old cable near the pulley and just let it (old cable) squirt out during the raise/lower process.
Thanks for all the help.
Eric
PS. If I'v missed some fundamental aspect, please let me know. Oh, and hostage, that's a very good point about dangers. We do have a well marked channel and I would stay in it, but also I'd just like to be able to start the motor periodically. I don't have a hose bib near the boat, so muff's are not really an option.
-ew
