bowtie2440
Thread starter- Joined
- Jun 22, 2010
- 20
Any info would be a great help . I went to check a few things out the other day I put muffs on instead of a tub I use I noticed I wasn't pumping water . I had thought I was pumping water the first time I looked over the boat . I didn't run the motor long enough for the buzzer to trigger both times. Well I dropped the lower and inspected the pump everything was new and in good shape so I searched a few forums something come up about the upper drive shaft I looked between the power head and the steering arm
I seen no shaft . I loosened the mounting bolts and tilted it back no shaft no coupler . I've been searching and searching I cant find the upper shaft NLA is what I'm getting everywhere I look but I found a coupler and dowel pin . I thought about finding a drive shaft from another unit and cutting the splined part but I'm stumped on the length , diameter and number of splines . Does anyone know where I can get all three parts new or used ?
Thanks
I forgot to add its a 89 Bayliner with a 125 Force L-drive
Thanks
