kohler genset won't keep running
ffraboni
Got a Kohler 6.5 cz generator in my 33 Carver aft cabin. The generator will crank but will only run as long as I hold the start switch.. dies as soon as I let go. Anyone with similar trouble out there with a diagnosis?
Reel Poor
Re: kohler genset won't keep running
Oil level switch------check oil level
A/C voltage regulator failure------check the three fuses on the control box. If it's not producing 120 volts it will not continue to run.
tropic
Hi ffabroni i have the same problem whit my kolher 4.0 kw gen
Are you letting go of the switch as soon as it fires? Just bought my boat and had the Kohler repaired. I have to hold the switch until guage shows it is producing power.
Jeff
tropic
Hi, jeff how much time do you hold the switch?
tropic
I need more time than this about 10 sec
Carlos
