Kohler 5E will not turn over
Butch5220
My Kohler 5E will not turn over with the start switch. Serial number 0625674. It is in a 2000 Rinker 270.
If I jumper the solenoid it turns over fine.
I have checked the following with either a volt meter or ohm meter.
1. Rocker start/stop switch
2. Both fuses. The fuse itself and the connectors.
3. The breaker connectors.
Have checked for loose wires.
Removed, checked, and reinstalled all connections.
I found a schematic and traced the "71a" wire . It has good connection all the way from the starter relay solenoid to the Bosch relay. The Bosch relay shows 12 volts going to it all the time. When I hit the start toggle one of the terminals reads 1 volt but the "71a" terminal will not read anything.
Does this mean that it is probably the circuit board or am I missing something.
Thanks for any help,
Henry
Butch5220
Re: Kohler 5E will not turn over
Is there maybe a better thread to post this? Maybe a different forum?
