skydiveD30571
- Feb 13, 2012
- 1,042
Volvo Penta 5.0GL-H with SX-A outdrive.
I just finished making some idle adjustments and went out for a test drive. It now idles great in gear, right at 600rpm as the manual suggests. In neutral it idles slightly higher at 800rpm. Is this too high for neutral? The reason I ask is because I started having some issues on the way back to the dock.
I was running low on fuel so I decided to head back to the dock. This is when I first started noticing that shifting to forward and reverse was making a "clunk" louder than normal, and required a little more force than normal. I cannot say if it was doing it sooner in the day, but this is when I noticed it. I cruised back to the dock at various rpm's ranging from idle to WOT, maybe a 5 minute trip. Once in the cove I brought it back to neutral to wait on another boat leaving the dock.
Right then I noticed a knocking noise coming from the stern. I am not 100% sure if it was the drive or the engine, but I am led to believe it was the drive. Funny thing is it ONLY happens in neutral. Once I shift to either forward or reverse it is gone completely. Once on the dock and heading towards the truck, the driver popped it into reverse and then forward, and I could easily hear the "clunk" a couple hundred feet away. It has never had this issue before, or any issue with the lower unit for that matter.
I checked the lower unit oil before trailering to the lake and it was clean (clear and greenish color) and full. What would cause it to suddenly start shifting rough? What could cause a knocking noise and be isolated during neutral idle but not in gear? Is 800rpm neutral idle too high? Like I said it idles perfect in gear, and 800 doesn't seem like it would be high enough to damage gears when shifting. Thanks (again) for any input...it seems like everytime I fix something I get a brand new problem
