Knock knock ??
agefhx
Have a loud eng knock in a 1974 85hp merc. <br />Split the case expecting to see some dammage and everything looks good! Only thing i found so far was lower crank bearing a little noisy and had a tiny bit of play in it. Is that enough to cause a loud engine knock?
12Footer
Re: Knock knock ??
Yes it is enough. But also check the wrist pins at the piston.
