I have a 1985 xr2 that i'm putting back on my boat after being off for about a year. I forgot where to kill switch wire hooks to the motor. Could someone help me out as to where it goes. Diagram would be helpful. Thanks Lee
what kill switch do you have ? i just went through the same situation myself with an 89 xr2. i used an aftermarket switch. depending on the switch. you have to use the black wire with the yellow stripe and a common ground. with a little more info , ican help in more detail.
It's just an after market switch. Had it hooked up and running a year back,just can't remember where to hook it on the motor.Had the motor off doing restoration work. Thanks for the reply
