Re: Kicker mount
My main concern is the thru holes for the bolts and sealing them. Thinking of using a silicon caulking on bolts then around head after tightening.
Sillycone and boat's don't go together. Use 3M 4200 (Home Depot) or Attwood 7200 (Walmart) polyurethane marine sealant. Jam a bunch up in the holes and move a screwdriver around in the holes to coat, the inside of the holes, then coat the bolts. Put enough on so it squeezes out when everything is tightened down, then clean up the excess with paint thinner and some paper towels. You don't need a bunch gobbed everywhere on the outside, it's what's on the inside that counts. (that sounds kinda' mushy and sentimental...)
What type of bracket did you get?
One thing to check before drilling any holes, make sure the brackets that bolt to the transom are parallel and flat. The brackets on my Garelick bracket were pulling together, canted inward, because of all the spring pressure. I had to jimmy some shims in between them (to keep them straight) so I could mark the bolt holes accurately. Also, all the hardware on my bracket was kind of loose. I tightened it up enough to take a bunch of slop out of it, but loose enough so it would still operate.
