key will not shut off motor
hunkymonkey
I replaced my motor with a 1985 to1990 OMC Sea Drive 225hp Looper outboard. I purchased a used Evinrude controller with all cables.I had to rewire motor cable harness witch is an 8 pin plug. all that went well. Now I can start engine but when i let key go it stays in the primer mode. When I put key in off position the motor purrs like a kitten. Now if I set it back to the run position it acts like it's being choked. back to off position then it runs great. So now my off position won't shut off the motor. I'm baffled and don't know where to go from here> My thought is it's a Looper motor could that have any difference in wiring to the controller? The other thing is controller does not have an emergency shut off key.IDK LOST. Oh I have been going by the manual that came with engine.Please help I'm ICHTIN FOR FISHIN!!!
emdsapmgr
I've had a couple of V6 crossflows which would not shut off when the key was turned to off. Found that one power pack kept 3 of the plugs energized, and the other power pack shut the other 3 shut down properly. I my case, I replaced one of the power packs and that fixed the problem. I know your engine has a single pack and do not know if it is susceptible to the type of failure mine suffered with.
