Key West Sportsman 1900 Ground Issue
grumann
I have a 2003 KW sportsman 1900. Does anyone know if there is a grounding block that grounds are run to? I've lost my live well, running lights (not anchor), etc. Any thing that has a ground running to it directly still works (radio, fish finder, anchor light). I'm assuming there is a block somewhere that these grounds connect to. I looked in the bilge where the battery is, but I didn't see one. Battery is fine and has grease covering all connectors.
GA_Boater
Look under the dash for a buss. While you're there check for voltage too. It may not be a missing ground.
