key switch wiring
Ozzman
I recently purchased a 1975 trihull with 70hp johnson, it came with new controls but the ignition was not wired. There is 8 wires coming from the harness, there is purple, red with purple stripe, black with yellow stripe, white, purple with white stripe, tan, grey, and black. On the key switch it has A,S,M,M, and B. The tilt trim setup looks like it was removed. Any help would be greatly appreciated. thank you
jtexas
Re: key switch wiring
purple = A
red/purple = B
black/yellow = raised M
black = other M
purple/white = C
white? shouldn't it be yellow/red? for S
tan goes to the overtemp horn, the other post on the horn gets a purple jumper from post A
gray goes to the tach SND terminal
jtexas
just noticed you didn't list "C" -- did you forget, or is it a 5-post keyswitch? maybe you have a separate choke button instead of "push-to-choke"?
no matter, if that's the case put the purple/white wire on one terminal and a jumper from keyswitch "B" on the other. If you don't have a choke button, a push-button momentary switch (normally off) from the car parts store will do.
[excellent link, Randy]
Ozzman
Thx for the replies guys, yes jtexas it is a 5 post keyswitch. I am going to work on it tomorrow night, i will let u know how it goes. once again thx for the help :)
