key switch wiring for 1975 70 hp johnson
Ozzman
I recently purchased a 1975 trihull with 70hp johnson, it came with new controls but the ignition was not wired. There is 8 wires coming from the harness, there is purple, red with purple stripe, black with yellow stripe, white, purple with white stripe, tan, grey, and black. On the key switch it has A,S,M,M, and B. The tilt trim setup looks like it was removed. Any help would be greatly appreciated. thank you
jtexas
Re: key switch wiring for 1975 70 hp johnson
purple = A
red/purple = B
black/yellow = raised M
black = other M
purple/white = C
white? shouldn't it be yellow/red? for S
tan goes to the overtemp horn, the other post on the horn gets a purple jumper from post A
gray goes to the tach SND terminal
Bruce W
I have a simlar johnson wiring question regarding the shift handle swich. How do I wire in the shift handle switch?
I know this is an older thread, but it helped me out a TON so far. I'm about to buy my replacement key switch (got a free control box because the iginition was drilled (lost key) but I have a question; will any year, any model marine key work? or does it have to be specific??
p.s. it's for the 1975 evinrude in my sig.
Silvertip
Honorary Supreme Mariner
An I/O ignition switch is very different than a magneto ignition switch so YES -- you need a six terminal OUTBOARD ignition switch.
How come all of the magneto outboard ignition switches I can find are 5 terminal?
