keeping it on the water
trickywoo
I am trying to find ignition for a '64 20 hp mercury, will a '67 9.8 ignition fit? Having real hard time finding exact part.
Thanks in advance
littlerayray
Welcome to Iboats not sure about your question but someone will answer soon enough
Chinewalker
Are you looking for ignition parts? Like coils, points and condensers? If so, then yes, parts from a 1967 9.8 will fit the 1964 20. You can also get points and condensers new, right here on i-boats (part number 18-5007). And I believe the coil, #[FONT=arial, sans-serif]18-5178, will work for you, too.[/FONT]
If you're talking about an electric start set-up, then no, they won't work.
trickywoo
Thanks, I need the whole thing, I have coils and points from a ton of old engines I have, even some champion hotrods but the castings and plates are missing on this engine
trickywoo
FOUND ONE!!!!! marineengine.com, has two, found a lot of hard to find parts there for anyone else that might be interested in the older engines
