Keel guard
kdmiller8251
Looking at getting a keel guard for the boat, but the boat is trailered and the bow roller is right under the front where the keel guard would go...<br /><br />Any thoughts??<br /><br />Tallman
roscoe
Re: Keel guard
Just let the air out of the tires, that should lower the trailer at least 3 inches. :) <br /><br />Sorry, I couldn't resist.<br /><br />Also sorry that I have no safe recommendations for you.<br /><br />Is this on you cuddy cabin?<br />Or a smaller/lighter boat?
dkhntr
Re: Keel guard
if it is a roller trailer you just need a few inches. Push it back. If you have a bunk, Get about 5 friends and push it back. ;)
rogerwa
Re: Keel guard
When I installed mine, I put a 12x12 block of wood along the keel behind where the guard was going ot be installed. I then jack it up just enough to take the pressure off the roller. I remover the roller and mount and I had clear access.
kdmiller8251
Re: Keel guard
The thing that I am worried about is how will the guard work when I bring the boat on the trailer at the ramp? Will it come off after use because of hitting the roller etc???<br /><br />Tallman
roscoe
Re: Keel guard
That sounds like a good question to ask the manufacturer via email on their website.
rogerwa
Re: Keel guard
The install instructions say that you should mount it about 9" (If I remember correctly) from the bow eye. So you should not hit the edge of it with the roller.<br /><br />They also say that the KG should not be resting on the roller when on the trailer. I found that an impossible instruction to follow without redsigning the rollers. What I did was to place the roller diffrently so that when the boat was up against the stop, not as much pressure was on the keel roller. I also made sure it rolled freely and didn't bind with weight applied. It's not perfect but after a year of launch/retrieval/ and sitting on the trailer it looks just fine..
