bubbakat
Thread starter- Joined
- Oct 29, 2002
- 3,110
This is a service bulletin I just received from a good friend who is a GM wrench<br /><br /><br />Document ID# 1468758 <br />2004 Chevrolet Chevy C Silverado - 2WD <br />Info - Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES) Light On as a Result of the Installation of an Aftermarket Reusable, Excessively Oiled Air Filter #04-07-30-013 - (Mar 5, 2004)<br />Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES) Light On as a Result of the Installation of an Aftermarket Reusable, Excessively Oiled Air Filter<br />2004 and Prior Cars and Light Duty Trucks<br /><br />2003-2004 HUMMER H2<br /><br />DO THIS<br />DON'T DO THIS<br /><br />First, Inspect the vehicle for a reusable aftermarket excessively oiled air filter<br />DO NOT repair under warranty if concerns result from the use of a reusable aftermarket oiled air filter.<br /><br /><br />The installation of an aftermarket reusable, oiled air filter may result in:<br />Service Engine Soon (SES) Light On <br />Transmission shift concerns, slipping and damaged clutch(es) or band(s) <br />Engine driveability concerns, poor acceleration from a stop, limited engine RPM range <br />The oil that is used on these air filter elements may be transferred onto the Mass Air Flow (MAF) sensor causing contamination of the sensor. As a result, the Grams per Second (GPS) signal from the MAF may be low and any or all of the concerns listed above may occur. <br /><br />When servicing a vehicle with any of these concerns, be sure to check for the presence of an aftermarket reusable, excessively oiled air filter. The MAF, GPS reading should be compared to a like vehicle with a OEM air box and filter under the same driving conditions to verify the concern.<br /><br />Transmission or engine driveability concerns that are the result of the installation of an aftermarket reusable, excessively oiled air filter are not considered to be warrantable repair items.<br /><br /><br />GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.<br />© Copyright General Motors Corporation. All Rights Reserved
