Re: Just put in telltale, nothing coming out
It's usually pretty obvious (or at least mine was). The impellar will have
either distorted or torn 'tabs' (wings, legs, whatever) or there could be a
tear in the key slot where the driveshaft grabs hold and spins it. Also, they
need to be installed the correct way, I've heard and the best way to assure
that is to grab the driveshaft and twist counterclockwise. That will turn the
tabs the right way? Don't know how much it matters but the instructions
from the new water pump kit read that way, anyway.
For what it's worth, on the mid-size engines (my 50hp anyway) the water
pump is on the very top of the lower unit. Basically, if you see the bolts
that are attaching the lower unit, the pump sits right there, so you can
see where not enough water can be an issue. I trimmed two sides of my
round 'ear muffs' so it would rest flat. Just used a pair of shears and cut
it right off. Seems to work better, but for the most part, if water is
entering the intake at a steady rate, that should be enough.
I want to update my earlier contribution, however. Once I changed out the
impeller and cleaned up the water pump, water was spitting out as soon
as I started it, basically. I only had water to just over the cavitation plate.
I'm sure there's a lot of variance, however, in these older motors.
