MostlyHrmlss
- Mar 18, 2008
- 57
1985 85hp powerhead installed on 1978 85hp everything else. Just serviced lower unit (new impeller, cleaned friction plate and pump housing, new oil). I put it all together, installed the telltale, put on the muffs, cranked it up and I get no water out the telltale at idle and a little faster (didn't want to rev it too much with no water). Removed the thermostat housing, still no water. There's plenty of water coming out the exhaust port and the two holes halfway up the midleg, just nothing from up top. Dropped the bottom end and shot water up the pickup tube, some came out the thermostat hole, most came out the exhaust; shot it down the thermostat hole, it came out the pickup tube, so I figure the passages aren't blocked.
What else do I look for?
