Just one more time. Temp gauge & sender
local825
I have a 79 85hp evinrude. I hooked up a Amega Teleflex gauge, hooked up a sender to the head screw, with the engine off it pegs to 240 with the ignition on it wants to go further. Wires are grounded but this sender also seems to be acting as a ground. I was thinking maybe the sender is not compatiable with the gauge any suggestions? ps.. can not find a sender just for evinrude or this Infamous Z BRACKET........:confused:
Sixmark
Master Chief Petty Officer
Re: Just one more time. Temp gauge & sender
Did you use your existing sending unit or one supplied with the new guage, as they may not be the same sending unit.
local825
Thank's 4: 30 am and mind is still one trAC ON THIS DILEMA, pulled up site and I believe this is a good place to start.......
