Daddy5295
- Jul 31, 2007
- 56
02' 4.3L Merc. Pulled motor, rear main was leaking. Took oil pan off to inspect. The cam is bad (pitted lobes on 5 different lobes). Main bearing under oil pump is pure copper. The others aren't to bad. Motor was rebuilt 3 yrs ago due to not winterizing(previous owner). My question is??? Will a car or truck 4.3L work in a boat. Using my intake, flywheel, heads and I know I will need to buy a new cam and lifters anyway right? I'm just not sure whether to rebuild what I have or go to the salvage yard and find a low mile motor. Are marine motors special, as far as the block, oil pump, etc, etc.
I knew I should not have put the plug in on the last outing
