Re: Just how difficult is it to rebuild an outboard?
Just an update to a thread from long ago...
I took the motor to a mechanic who specializes in older motors like mine. I didn't feel comfortable doing the work myself nor did I have time. In my experience, I usually spend double when trying to save money.
SO the results were....
- piston #4 had a hole in it and rubbed a gouge into the cylinder so it's getting re-sleeved
- piston #3 had a small hole in it but no re-sleeve
- piston rings were badly worn on all 4 pistons
- over-reving in driveway did not cause any binding problems, just blew out one of the piston rings and loss of compression which may have resulted in hole in piston
- crankcase looks great
- crankshaft is in great condition
- piston rods look straight and should be in good shape
- carb was in bad shape which may have been the cause of my blowby and other damage over time
- reeds and intake look great
- no boring, all cylinders will be factory spec when complete
- using fancy new Weisco tefflon coated pistons in all 4 cylinders
- full re-hone in 3 remaining cylinders only, no boring needed
- all new gaskets
- new carb rebuild
- possible new coils
- testing entire electrical system for any possible flaws where anything will need to be replaced
- new starter (not rebuilt) for only $100
- motor will be like new and have a 15month warranty
All of this for around $2,500 including parts/labor. I'm happy with that and after checking several shops, this was one of the cheaper bids and I know the mechanic cares about doing good work vs. the money. He's been sending me photos, keeping me updated, and answered every single multiple question I have asked. Very happy!
After reading many posts on here and help from others, I feel much more informed on the subject and I can tell if I'm being given a dose of BS. This guy is highly recommended and does great work. I'm happy! THanks again for everyone's help!
