Hi everyone.
Well after a lot of searching and reading I had to post in hopes of getting some guidance. I recently bought a used boat with a 1998 Johnson 50 spl (2 cyl.) and I can't keep it running on it's own. Can spray fuel mix in the intake and it runs rough. The previous owner said that he was having the running problems with it and his mechanic said he "thought" the timer base needed replacing. I bought it with that understood.
So far I have:
*Compression tested: top cyl. 120 -125 -125 bottom cyl. 130 - 125 - 125
*Spark tested with tester set at 1/2" gap, strong white spark, could even hear it ticking as it sparked.
*Removed the flywheel, all magnets in tact and look good visually. Removed the stator and it looks good as far as no melting or loose wires, nothing burnt visibly. Removed timer base and visually looks fine. Replace it and it rotated back and forth freely as it should. Reinstalled stator and flywheel.
I plan on getting a DVA adapter to test all the electronic parts if it comes down to it. That's where I need some guidance on how to proceed.
Did all the following together in hopes this would fix it:
*Checked and cleaned the fuel filter, Emptied the fuel tank (let residue evaporate) then blew it out good with a long air gun. Put in fresh gas/oil mixture. Bulb works fine and in the right direction, gets hard when pumping carbs full.
*Removed fuel pump and took it apart. All "looked" good inside. Diaphragms were still flexible, no splits, tears or holes. This is a VRO pump but the previous owner started mixing the fuel/oil (50-1) and stropped using the VRO (oil) side. He capped the oil line by the fuel connection and unplugged the wires that ran it. I don't know if the oil side still works or if it failed. The fuel side appears to be working but I haven't pressure tested it. Took the hose loose on top of the pump and it gushes fuel out when turning over the motor.
*Removed and cleaned carbs. One carb had a slight bit of gumming in spots on the bowl but other wise fairly clean. Completely clean after i finished, all jets/ports/tubes cleaned with a wire ran through them and carb cleaner, then blown out with compressed air. Previous owner had them rebuilt a year ago but let it set up several months so I didn't want to chance it.
*Put in new factory recommended spark plugs.
When I tried starting it (on muffs) for the 1st time after all the above was done it wanted to run and idle on it's own but ran rough (working the cheater lever to). I had the idle air screws both set at 1 3/4 turns out from seated. Hoped it would stay running to try to adjust them but couldn't get that far, it would die. Seemed to become harder to strat and run worse the more I tried. After about 5 mins of trying I had to start giving it a squirt of fuel mix and starter fluid in the intake to even get it to run. Would only stay running with fuel mix sprayed in intakes and working the throttle linkage. If I stopped either it would die out. So that's where I'm at now.
My question to those who would know is would a bad timer base even give me the symptoms I'm getting? Does it sound like an electrical part issue or definitely fuel related?
I"m leaning towards getting a new fuel pump, non vro, just on the basis that I can keep it running with a spray bottle of fuel mix. But I wasn't certain if an electrical part such as the timer base or possibly the power pack (I think?) would cause the issues I'm having.
I will probably order a DVA tester Monday but that'll take a week to get here. Unless I
I know it's a long post but I wanted to be as thorough as I could. Thanks in advance for and help or advice.
So far I have:
