'01, Merc 2.5L, 200 EFI on 20' Triton...
Last Wed, one mile from ramp, I lost the #6 cylinder. Upon pulling the plug, head, then engine, it seems the fuel injector failed. Here's my observations when disassembling the engine.. #6 cyl, Totally dry.. (destroyed piston and need of being bored). Fuel in evaporator canister looked "green" like it should. Fuel filter was full of this yellow colored plastic looking junk. (filter was changed this spring). The screen on the high pressure pump (in canister) had some trash on it,(*1) but the fuel in the bottom of the canister was so full of particles, it was cloudy. And, after letting it sit overnight in a mason jar, the heavy participates settled out, but the fuel is still cloudy.
With the above info; What is the yellow crap in my fuel filter? What is the junk (*1) in solution that I poured out of the canister that is making the fuel cloudy? Could this be the cause of the #6 injector failure?
I'm very picky where I fuel my boat. I always go to stations which move a lot of fuel, so the fuel stays fresh. I'm wondering if I just got some BAD fuel or if someone has dumped something into my fuel tank causing this...(and yes, I've already drained the fuel tank into 5 gal jugs)
Second: I'm thinking of just buying a PRO XS and being done with it.. (since the damn injectors are $500 ea, and I haven't even began on the block)(they are going to Tony Brucato before a decision is made)... Whats the difference between a plain Optimax 225 and the ProXS 225?
Thanks in advance.
Thanks in advance.
