Jphnson 1995 4 stroke 9.9 oil change
Chrism1367
Hi I've looked everywhere and can't find how to change the crankcase oil. I know, get a manual. I'm working on it but thought if I'm missing something obvious someone could yo ld give a quick answer. Btw 75 bucks for a service manual sucks. Also motor doesn't run, will only start at wide open theottle. Thanka
Vic.S
Drain the old oil via the drain plug low down on the exhaust housing #24
convert
Change the oil filter
Refill via the filler on top of the crankcase until the level is correct on the dipstick
The manual will tell you the required volume of oil. (1272 ml I believe).
Chrism1367
Ok thank you. I'm assuming I have to remove the plastic cowl on top, the pull start casing to get to the dipstick? Btw I did a compression check and it's not good. Got 40 on top and 70 on bottom cylinder. This was cold with no throttle. Problem I am having is it will only start at almost full throttle, and if I back off it will die. I've cleaned carb, new plugs and wires, has good spark, test at 1/2 inch on air gap tester. Also pulled plug after trying to start and plugs were wet with gas. Also when I use pull start there doesn't seem to be as much resistance. This is kind of a last ditch effort. Also I emptied gas tank with new gas and vent was wide open. Anyone have an opinion? This boat and motor was a gift from wife's grandmother which has been used by the family for years and don't know if it has ever been tuned up
Honorary Supreme Mariner
Nope----No need to remove cowlings to drain the oil or to find the dipstick!----Looked at 1 of 3 of these motors I have for parts / repair.-----Compression test needs the throttle open.----And check the valve rocker arms and the valve clearance too.-----There are some known issues with these rocker arms !
ondarvr
These were also odd motors, with inherent issues, not worth putting any money into it.
Chrism1367
Thanks for the help! Gonna give this motor a couple more tries but if it doesn't run guess I'll be looking for another. Thanks again
Well you may have to remove cowlings to remove the rocker cover to check valve clearance.-----No need to remove the cylinder head for that check.-----Note---cylinder head gasket is ~ $100 I think
Chrism1367
Ok update, I went to marine store to get oil filter, my model is j10releoe, and parts guy said it is 2 stroke....all four strokes start out in j10f, this motor has been run for hours and hours on regular gas, how is this possible? Also the oil filter should stick out on the side of the motor, I can guarantee there isn't one sticking out on mine. If this is true, the motor is gone, and I feel like an idiot
Vic.S
Yes that is the number for a 2 stroke
The equivalent 4 stroke would have been J10FRELROC
I think an owners manual would have been a worthwhile investment! but why you thought it was 4 stroke beats me!
If it was a 4 stroke you should have been checking the oil level on the dipstick regularly !
For the record later 4 strokes have a 4 in the model number before the date letters
Chrism1367
Well I didn't check the level because last year the owner said all oils were changed, and didn't bother looking for it. Stupid mistake, I'm old enough to know I should have dug into it further, yes I'm beating myself up for this. On a good note, nothing is seized and it turns over freely, although I think low compression seems to turn it over too freely. I put a little oil in each cylinder and could tell the difference when I tried to pull start it. It fires some but just doesn't want to catch. Gonna mess with it tonight and tomorrow and see what happens. Thanks for the info
Sorry, just another example of why model numbers should be posted.---And another example of the statement--" Outboards rarely get a chance to wear out. They are destroyed by people who just do not know fine machinery "----You are looking at an expensive rebuild or a new motor.
ondarvr
If you ran it for long without oil it's total rebuild time.
Chrism1367
Well we're most likely gonna bite the bullet and buy a used one. Btw I rented a compression guage from AutoZone, are those sufficient for a two stroke? The readings I got are 70 top and 40 bottom, engine cold as I can't get it started
I think if you remove exhaust cover or cylinder head you will see the damage.----A compression gauge does not know if it is on a 2 stroke or 4 stroke cylinder !
