Re: Jonny/Rude Carb Jet Questions
I also have an 81 johnson 2 hp 0ne cylinder job, I took the coils from the 3 hp and tried them in the smaller engine and it ran better then ever with each coil. so I bought a new coil for the 2 hp. The ignition system seems to be OK.<br />Flooding is my main problem, I have disassembled and cleaned the carb half a dozen times. It still floods if I choke it at all.<br /><br />Please, Does anyone have a picture of the two Reed valve gaskets?? I had to make them and I may have done it wrong,and also a picture of that darn carb screen??<br /><br />The factory service manual I got from E Bay said if an O ring was on the crank just above the oil slinger I should remove and discard it, that it was there for shipping purposes only. I installed a new one there before assembly thinking I was doing the right thing. It that a possible problem?????
