Jonhson 70 stalling
sambeau21159
My oncle gave me his motor that didn't run for 5 years. I chaged the oil and the spark plug.
It start and run well on idle, at first it run great at full speed by after few minutes ?5min it stall cut off. I can start it but then it can't put full gas or it stall again, i can only put on just enough gas to move a little.
If we let it cool down for 20 min, we are able to run full speed again for 5min, but then same problem happen.
Any help or cue would be appreciated
oldboat1
sounds like it's overheating. Make sure it's pumping water -- likely need to change the impeller before additional running, certainly h.s. running.
emdsapmgr
Agree. Check to see if the overheat system is working on the engine. Esp, make sure the hot horn in operable/audible inside the control box.
