Re: Jonhson 25 cyl head?
Okay, I have tried plug wires from my other motor and checked resistance (about 0 ohms both). And original wires have 0 ohms too. The coils have a mounting tab for grounding and the upper mounting bolt goes through the tab. Tabs are shiny and the mounting surface is clean. I was wondering, could it be possible that the power coil is too far from the fly wheel magnets and because of that giving less power to the ignition system? But when I changed the Power coil last year I did mark the spot where the old one used to be. The old PC was dirty but gave 856 ohm resistance. New one gives almost the same. I haven't checked any voltages from this motor.
I have L77JC4 plugs on it, tried also with Bosch W4AC, Champion L78V and NGK B6HS. No affects...
I think about giving one or two more chances for this motor. I got it so cheap that I think it's worth fixing being only 12 years old..
