Re: Jon Boat Mods
foam from Home Depot, and then cut 1/2 plywood to fit
I did something similar, but used 3/8" ply, 1" stringers between the boat ribs and then filled the void under the floor with foam (stringers the same height of boat ribs).
1- cut plywood to fit leaving 1/8" gap on ends and 1/4" on sides for carpet and water drain.
2- Gorilla glue and screw stringers to the bottom of 3/8 exterior plywood
3- seal wood with several coats of urethane/resin
4-
line boat hull with thin painters plastic very important unless you want the floor hopelessly stuck in place!
5- heavily mist plastic and floor underside with water, very important for foam cure
6- apply a few cans of spray foam insulation to the bottom of wood floor (not too much at once, easier to add more later than have it over fill)
7- set floor in place and weigh down with 2-300# while foam cures, front deck should cure overnight so it takes the boat's curvature
8- remove floor, add more foam to fill voids, weigh down again and cure
9- trim foam that filled the channels (so water can drain)
I used 3/8" ply because I wanted it light and after doing some testing found that 3/8 wouldn't flex with the support I was using. I'm 250 and the floor feels rock solid.
Wondering how the heck I was going to get the front floor to conform to the curved bow, a light bulb clicked on as I walked into Lowes and saw the top sheet of 3/8" ext ply, the one no one takes. It was flat on one end and warped up on the other end, perfectly flat for the back and almost a perfect curve for the bow. Even though the warped sheet was close to the boat's curve I hosed it down and let it dry in the hull (several times) to perfectly conform to the shape of the boat's hull.
I also cut out the middle of the box seats, rolled over the edge 1" and lined the cavity with 2" foam. 2- Group 31 batteries, 3 gallon gas tank, anchors, ropes and life jackets fits under the middle seat. Same amount of storage under the rear seat.
There's a lot more too, maybe I'll post a thread on the build?
