Jon boat: Adding plywood decking. How to seal
joulian
Hey guys , I am working on adding a front deck and back deck to a 16' jon boat ( its a little over 4 ' wide at top). How do I need to seal the wood. It is marine grade plywood. I have heard you are suppose to seal it off where you cut the new pieces. What do you seal it off with?
roscoe
Re: Jon boat: Adding plywood decking. How to seal
Spar varnish works well, several light coats.
NOT polyurethane !!
Or use an epoxy resin.
You must seal the entire piece, not just the edges.
Bob_VT
why not polyurethane?
Because it will not survive the marine environment and spar varnish will since the spar has uv inhibitors.
kfa4303
Banned
+1. You can even get spar varnish at lowes/HD, but you usually have to order epoxy. I'd say a few coats of Spar varnish followed by a top coat paint of your choice. Although, lots of folks just leave the wood unpainted after using the varnish. However, if you do paint Rustoleum oil based enamel is an oldie but goodie and holds up well on the water and you can get it just about anywhere. It takes a while to fully cure and can be a bit slick when dry, but it works great. I did several coats on 2 decks and 2 benches with less than a qt. Pay special attention to the cut edges and pick up some 3M 5200 (also at lowes/HD) to dip all of the hardware you may be using in prior to installation. (btw only use Stainless steel or aluminum pop rivets in a boat.)
jigngrub
For those that don't know, there is an exterior grade of Spar urethane that has the UV inhibitors. It's the Minwax brand.
http://www.google.com/products/cata...RIreT8v0GoKQ8wS03PiDCw&sqi=2&ved=0CIwBEPICMAU
I'm not really sure that UV inhibitors are that important if the decking is going to be covered with carpet or something else.
Epoxy resin is the best sealer, but it doesn't have UV inhibitors so it needs to be covered.
joulian
Thanks guys .....
