Re: Joined the no plug group - BIG TIME
Anything that could go underwater should always be soldered. Then you can heat shrink it. Saves a boatload (hah, what a pun!) of headaches down the road.To fix it I used a heat shrink butt splice. Before I put one of these on I always apply some di-electric grease to the stripped ends of the wire to seal the connection from the air. Also, I pull on the crimp to make sure it will not just slip out of the crimp. No known failures that way YET.
TerryMSU
