Johson Prop
RLDuck
I have a 15 HP two cycle and will be pushing a 16 River Hawk with about 600 pounds on board--ani idea on what pitch prop would be best for fuel economy with speed not a factor or any ideas on what would just run best?
Mod2
Re: Johson Prop
RL...I'm going to move your post over to the "Prop Topics and Questions" forum.
rickdb1boat
Re: Johson Prop
Michigan Prop selector says a 9-1/2" X 10" pitch is the standard prop. If that will work for you depends on the actual weight of the boat and load. There aren't too many pitches offered for that combination...<br /><br /><br />3 Blade 9-1/2" X 10" RH #012111 MICHIGAN MATCH<br /><br />3 Blade 10" X 7" RH #012112 MICHIGAN MATCH<br />(Would be for a heavy load)<br /><br /><br /> web page
Lubosleftboot
Re: Johson Prop
Originally posted by rickdb1boat:<br /> Michigan Prop selector says a 9-1/2" X 10" pitch is the standard prop. If that will work for you depends on the actual weight of the boat and load. There aren't too many pitches offered for that combination...<br /><br /><br />3 Blade 9-1/2" X 10" RH #012111 MICHIGAN MATCH<br /><br />3 Blade 10" X 7" RH #012112 MICHIGAN MATCH<br />(Would be for a heavy load)<br /><br /><br /> web page
Hi Rick that link you have posted no longer works buddy :confused:
