Sounds like maybe it is running out of fuel and stops. If so, it is a fuel delivery issue and that can mean fuel pump, fuel lines and the carb(s) as well. Time to investigate where the problem is. Remove the line going from the fuel pump to the carb and crank over the engine. See if fuel comes out of the fuel line. If so, then time to rebuild the carb(s). Buy a carb kit and remove the carb, disassembly it/them and use carb spray and compressed air to clean all the passages out and install the kit... If fuel doesn't flow out the fuel line properly, time to rebuild or replace the fuel pump. That should get you going again... :thumb:
