Johnsos 9.9 only runs on bottom cylinder
Tophpj
My Johnson 9.9 out board 87 model stopped running on the top cylinder while I was a sea. I have checked the connections, tried the plug and lead off the bottom, even tried swapping the coil packs to no avail.The coil does spark , but how do I test it and is it the coil or the CDI
gm280
:welcome: aboard Tophpj. Nice for you to join us...
Okay since you've already swapped the coils around and verified that both coils are working, it seems there is a power pack module that feed them. Are the wires connected good on that module? There are two sets of wires that come from the power pack that feeds the coils. Make sure they are good and not broken or pulled out of the power pack. If they are good and you still get nothing from it for that same coil, it could be time to replace it. The reason I say that is because the sensor the sets up the spark timing has to be working or you would not be getting spark on either coil from the power pack. JMHO
oldboat1
Disconnect the kill switch and try it. One of the wires is the single connector tucked in by the coils. Unplug it.
Tim Frank
How do you know the top cylinder is not firing?
Are you sure the bad cylinder still has compression?
oldboat1
The CD unit is a $90 part -- which you may need. But first test each coil for spark (use a spark tester). Also, the cutoff switch grounds the system -- prevents spark. If you lost spark, it may be that the cutoff switch is the issue. If that motor has a clip and lariat, did the clip get pulled? If the clip is not installed (red plastic button held out), the system will be grounded -- no spark. (Kill switch button will short out top coil.)
flyingscott
O P said he swapped coils and it sparked. Kill switch would kill the motor and he is running on one cyl. powerpak problem
Tim Frank
The way I read the OP, he has assumed it is an ignition problem. The tests he seems to have done rule out cylinder-specific electric components.
I ask again, how did he decide it is an ignition issue?
Is there a compression problem?
oldboat1
not really sure what the OP is saying about switching coils. seems to say he tried swapping coils to power the top plug, but didn't work -- but gets spark with that coil (i.e., the lower one). might indicate a bad plug.
may be right (flyingscott) about the kill switch, not sure. know one ground connection/wire goes to top coil mounting bolt, and second ground goes to the power pack(?) through a single wire connector.
Before spending money or going any further, would be rational to test for spark first. If no spark, would then check for a poor spring connection in the boot or bad plug wire. Then suspect/test coil, and somewhere in there, check compression, as suggested above. Then move on. Powerpak is a good guess, but for $90 or so, worth some preliminary checking.
w2much
I do not know your motor well but you may consider the fuel pump diaphram leaking to much fuel to the crankcase and flooding the cylinder. I have had this issue on other small outboards. Drove me nutty thinking it was an ignition problem.Easy fix, new pump for 45.00 or rebuild the one you have much cheaper but tricky
Honorary Supreme Mariner
If it was a sudden failure at full throttle it could be a reed valve problem.----Rusty spring in a plug boot would not kill the spark to the plug !!
oldboat1
think the OP might have limped back out to sea. Tophpg, you still out there??
