O P said he swapped coils and it sparked. Kill switch would kill the motor and he is running on one cyl. powerpak problem
not really sure what the OP is saying about switching coils. seems to say he tried swapping coils to power the top plug, but didn't work -- but gets spark with that coil (i.e., the lower one). might indicate a bad plug.
may be right (flyingscott) about the kill switch, not sure. know one ground connection/wire goes to top coil mounting bolt, and second ground goes to the power pack(?) through a single wire connector.
Before spending money or going any further, would be rational to test for spark first. If no spark, would then check for a poor spring connection in the boot or bad plug wire. Then suspect/test coil, and somewhere in there, check compression, as suggested above. Then move on. Powerpak is a good guess, but for $90 or so, worth some preliminary checking.
