Johnson ?
motorcop255
I've received an johnson eng. that I need to know what size and year model it may be so I can fix the leaking carb. The carb. will pour gas while not running. Model # JW21E Thanks.
Paul Moir
Re: Johnson ?
JW-21 is a 1966 3hp Johnson:<br />4000RPM@WOT<br />Displacement: 5.28 CID<br />Spark plug: Champion J6C (no other brand)<br />Fuel mix: Originally 50:1, you might consider running 32 or 24:1 on this particulair engine. They seem to live longer at it.<br /><br />The Johnny/Rude 4/3hp engines are perhaps the best small hp engines ever built. Common problems are a clogged fuel filter (above the brass nut on the fuel tank) and ignition coils cracked from age. Both are cheap to fix.<br />NAPA autoparts, or your local Johnson/Evinrude dealer can fix you up with a carb kit.<br /><br /> <br />Good luck! Good reading for 3/4hp owners.
motorcop255
Re: Johnson ?
Thanx Paul, Is it common for the carb. to leak, or maybe because it sat up for a while, it runs great now, just leaks while not running.And could you possibly place some kind of value on it, The motor is all original white in color with good decals still on it.
Paul Moir
Re: Johnson ?
I'd be willing to bet that the float or needle is just gunked up. The only time I've ever had a problem with a leaking 3hp carb, it was because the float was getting hung up on the bowl gasket because of an assembly error... <br /><br />Watch out for that clogged fuel filter, by the way. It seems to clog more at the bottom, so that the flow gets restricted only at under half a tank.<br /><br />EDIT: Oh, it could be that the float sunk. Sometimes they (old cork ones) get saturated with gasoline. Try floating it in a can of gas.<br /><br />Good luck!
tad7777
Re: Johnson ?
the leaking problem is the float in the carb,, it is not floating up & shuting off the fuel flow,,my 1970 has a cork float ,& it did get saturated , swelled up , rubbing the side of the bowl or hitting the gasket,, anyhow it is the float,,needs a carb rebuilt,,tad
