Johnson water pump impeller
BUBBAKZOO
I have a '68 Johnson MQ-14D and it has been in storage for about 3 years...It has been suggested that I change the waterpump Impeller...Is this a DIY repair? I know little to nothing about about outboards?
Any help would be appreciated
Bubba
78big10
Re: Johnson water pump impeller
i just brought to life a 75 evinrude after three years storage first thing i did was drop lower unit water pump was shot i knew nothing about it but with help from the great guys here they walked me through it works great think about carbs also very sticky
ezeke
The 9.5 is a fairly easy one to change. Four bolts and disconnect the coupler by removing the screw will get you to the pump. If everything is in reasonably good shape, you should be looking at about 1/2 hour. When you remove the 4 bolts facing upward, open the unit enough to find the shift rod coupler.
johnson1989
If you have some mechanical know how its pretty simple. Hardest part is usually getting the lower to drop and getting shift rod disconnected. Make sure you have all bolts removed and check under the trim tab.
http://www.meegsonline.com/tmd/waterpump.wmv
