Johnson water jacket replacement. 1979 55hp
Steve73
Hi All,
When installing the water jacket gasket should a sealant be used in conjunction with the fibre gasket? I have some Evinrude gasket sealer, and wondering if I should use it? Also is it recommended to use this on the bolt threads or some type of anti seize compound? Thanks for any info.
F_R
Honorary Supreme Mariner
Yes, that is the stuff to use in both places.
