Re: JOHNSON VRO 60 ,1987.
rale,<br /><br />You have to remove the entire tilt/trim unit. There are two pins that hold it in.<br /><br />Before I did all that, I would make sure all your connections and wiring/switches are good.<br /><br />Your engine doesn't have a choke. It has a primer system operated by a solonoid. It is the black cylindrical unit on top of the air box in front of the carbs. Make sure the red lever on it is pointed toward the body of the solonoid. In other words, folded down.<br /><br />Otherwise, I would think you may have a carb. problem.
