dog marley
Thread starter- Joined
- Oct 10, 2017
- 1
Hey there
Got an old johnson vro 40 for free.
It was standing outside (without cover
) 17 years in spain, it was new garage fixed but neither the attached glastron v145 fireflight, nore the engine touched the sea again since then ..
The vro is inactive, one tube (oil) closed up
Gave the carburetor a rinse/brush/wire clean, no gasket change yet (carb cleaner like seafoam cost 40$ here in spain :S, gasket change as I got money), checked connections, changed pump/tube, cleaned sparkpl and cranked it ..
After a few, we made it happen, that it runs for a short, not too bad actually, but then after 20 seconds backfiring and pissing out of the first carb where I marked in the attached picture, and after second backfire its mostly off.
Cylinder mostly flooded after some more attemps.
Repeated with same result.
Any idea, why spraying out there?
To tell the truth, its my first engine I work on, but will give my best, even with very limited capital ..
Thanks a lot
Damn, not allowed to upload ..
Well it is the top little hole above the main opening
(On that carburetor repair kit sketch it is no 9)
Thanks a lot
